:evil: :evil: :evil: I am so peeved right now that I can barely see straight!!! :evil: :evil: :evil:
Schultze had his 10K oil change & inspection today.
Picked him up around 5:30-ish.
Gave the gal behind the check-in desk the key to the loaner. They IMMEDIATELY wanted me to fill out the rating sheet. I said that I was going to wait until I got my keys and could check the car out.
They wouldn't even have a porter bring Schultze up until AFTER the rating sheet was filled out!!! :evil:
I filled it out and then used the comment section to write (paraphrased):
"Frank's customer service was excellent. I refuse to comment on the maintenance service until I have a chance to inspect my car. Which I can't do because they won't bring me my car until I fill out this form!"
I give it to the gal and then she calls up a porter to inspect the loaner.
I watch as not one, but TWO porters inspect the loaner top-to-bottom, inside & out! WTF???!!! :evil: :evil:
The two porters were calling in every-frickin-little-thing...as they found it...over the radio to make sure it had been notated when I took possession of the loaner this morning.
And before anyone suggests that a new porter was being trained...I can assure you that WASN'T the case...the two porters have been there ever since I brought Schultze in to get his bonnet stripes installed a week after I brought him home!
Now...thinking that I was being singled out, I watched as the next Cooper loaner was being inspected. One of the porters who checked in my loaner inspected it by simply doing a VERY quick walk-around and a quick glance to the interior. :?
I asked the gal why two people were inspecting the loaner when that's never been done before...she said "that's what we have to do with Cooper loaners." um...
okay.
Ok...that's not right...maybe it's a new policy...but it gets better!
ANOTHER Cooper loaner came in--did two porters do the check-in inspection? No, of course not!
A beemer loaner came in next...SAME THING: one porter with a very quick, barely glanced at, inspection!
So I finally get to be reunited with Schultze. The porter who brought me Schultze didn't even do a walk-around with me like they normally do!
Let me backtrack a bit...
After I had filled out the rating sheet they wanted me to sign-off on the warranty sheet so MINIUSA could process payment to CF.
The total amount to be paid by MINIUSA: $914.49!!!
First itemized line stated the oil service was just under $300.
Yes...three-hundred-dollars!!!
I make the comment that I'm sure glad I don't have to pay
THAT out of pocket...the gal tells me: "Oh, that price is the discount we get from MINIUSA. If you wanted to bring your MINI in for an oil change, it'd be more because you wouldn't get the discount.
As a "courtesy" the seat cover was replaced. The lumps are still there.
Cost to replace the seat cover? $400-something.
I asked if I could get a copy of the itemized sheet.
No.
May I ask why not?
It's not meant for public information.
She said she could write the info on my copy...however, instead of the itemized dollar amounts, she simply put the total dollar amount.
:roll:
So...I finally get to leave with Schultze.
Get onto 264 westbound when it starts getting windy.
Got to Campostella exit and it started thunderin' & lightenin'!
Got REALLY dark, REALLY quick...raining cats & dogs headed into the downtown tunnel...so I go to turn on my front/rear fogs.
NADA.
NOTHING.
Mind you, my fogs were working yesterday when I accidentally turned them on.
Called Frank and left a voicemail message telling him that the fogs aren't working.
The rain has finally subsided somewhat and I'm going to go out there and check the fuses in the driver footwell.
All this "extra attention" from CF didn't start until the settlement for the damages done to Schultze were finalized...I just KNEW that everything would be put under a microscope from that point on!!!
Oh...and the results of the temp. issue inspection?
Nothing was wrong. Thermostat, all sensors & gauges working properly and within MINI "specs".
Gee...what exactly WERE the readings? What is the spec range? How am I to know if the reading is closest to either end of unacceptable or in the middle?
I'm NOT feelin' the love from CF right now....
