RoyalGreyMCS
« on: October 01, 2007, 07:48:45 PM » |
OK, I have decided to start looking for new tread for my MINI. I am keeping stock s-heavies (s-lites) on but I was thinking I am going to go with some good old tires and nix the idea of run-flats. I am open for all suggestions on tire choice, as well as where to find the best deal. I was quoted $450 mounted and balanced for a set of 4 brand spanking new Dunlop SL Direzza 205-45-17. I am not huge into all this wheel and tire babble so, any useful information would be great. Thanks any and everyone!
Ventidue
International Merrymaker
Offline
Penicillin cures, but wine makes people happy.
« Reply #1 on: October 01, 2007, 09:54:32 PM » |
I have Goodyear Eagle F1 GS-D3's and they are AWESOME. You are going to get a bunch of suggestions, but you have to figure out what you like. I have had mine for 25k miles and they have not let me down. http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Eagle+F1+GS-D3
I wanna go fast! 'ven-TEA-doo-eh'
Cajun
« Reply #2 on: October 02, 2007, 06:57:19 AM » |
I just put blue streak stilettos on my S-lites. They are made by Goodyear, and sold at Goodyear. I think I paid about $350 for the whole set, and I love em. I did go up in size to a 215/45/17. The handling is fantastic. there is hardly any roll. and stay planted really good around a corner. It has a 320 tread ware, so it will last. No problems in the rain ether, they stick. Here is a shot of em.. http://www.treadepot.com/group/stil.html
RoyalGreyMCS
« Reply #3 on: October 02, 2007, 09:54:17 AM » |
Thank you both for the suggestions. I will continue my search and see what I can come up with!
RoyalGreyMCS
« Reply #4 on: October 02, 2007, 10:39:20 AM » |
I have the stock 205's on the s-lites, will the 215's fit without any issues in regards to being too big? Like I said, when it comes to the tire thing, I am a bit of an idiot because there are thousands of possibilities it seems!
Sean the Turd Polisher
Offline
I'm one of "those" people that don't own a MINI!
« Reply #5 on: October 02, 2007, 11:13:35 AM » |
http://www.miata.net/garage/tirecalc.htmlNathan, here's a calculator to figure tire size differences, it's on HRMINI somewhere as well. The 215 will be 0.3 inches taller than the 205's. Happy Number Crunching!
My Land Cruiser cancels out 2 Prius ... what is the plural for Prius?
Cajun
« Reply #6 on: October 02, 2007, 12:39:01 PM » |
I lowered my MINI 3/4" and have no issues at all with rubbing. So a stock ride hight MINI will have no problems. And it looks killer too.
Capt_BJ
« Reply #7 on: October 04, 2007, 11:20:14 AM » |
When I decided to leave the Rirelli RF on the 02 with S-Lites I first went to
Yokohama AVS ES100 @ $99 .... they were fine .... a softer ride than the RF's of course and wore OK but became a bit noisy as they wore, consistent with Tire Rack reviews. After about 25,000 I replaced with
Kumho Ecsta AST @ $68 ... I replaced a bit early as I was turning the car over to son and wanted full tread when I did that. The Kumho is the least expensive tire I found in the stock size yet gets good reviews. I found them to be very similar to the Yoko's. Both of these tires had the BIG improvement of not trammeling anywhere near as bad as the Pir's did.
I got both sets from Tire Rack, through Mike at Sports and Imports as he is a recommended installer from Tire Rack. In each case I called in the morning and he had the tires the next day and I had them mounted before the end of the day....
« Last Edit: October 04, 2007, 03:44:16 PM by Capt_BJ »
F15eWeapon
« Reply #8 on: October 08, 2007, 10:11:32 AM » |
Nathan, I recently moved to the Nitto Neo Gen tires.... so far, I love them. I haven't had it in the rain to test wet performance yet, but if it tells you anything for grip, I used to be able to get the tires to chirp when shifting at redline into second... and now they just stick. Actually... that kind of makes me a little sad. lol. They are engineered to work with lowered vehicles, and to wear better with vehicles with negative camber. They are cheap too... I think about $73 per on wheelsnext and discounttire.com
jrudy01
« Reply #9 on: October 11, 2007, 11:45:00 AM » |
Nathan If you decide to go Yokohama's I can probably get you about 50% off. look at parada spec 2, avs es100's, or the s drive tires. Jeff
minispec
« Reply #10 on: November 02, 2007, 09:02:00 PM » |
Nathan- Continental makes a very inexpensive run flat that has gotten great reviews on the Tire Rack site. It weighs about 7 pounds more than a simalrly sized non-run flat but if you're already in that deep with the s-lites, will it matter?
Of course, I could suggest the Rota RB in a 17x7.5 at "$150 per wheel and the Continental run-flat at $124 per tire that would total a mere 45 lbs per corner and still offer the convenience of a run flat in a lighter package....
Mark
PS- Please say high to my friends at CF- hope all's well for you!
RoyalGreyMCS
« Reply #11 on: November 03, 2007, 12:58:40 PM » |
Thanks for the info, will relay the hello to everyone.
