You are here: Home arrow Forum arrow Grease Pitsarrow Mini Classicsarrow Caliper rebuild
Welcome, Guest. Please login or register. December 01, 2008, 03:28:11 PM
Pages: [1] 2   Go Down
Author Topic: Caliper rebuild  (Read 315 times)
T.J.
Yippee!
« on: February 26, 2008, 09:05:16 PM »
I rebuilt my calipers today.  Replaced the pistons, seals, and the transfer seal.
Went from this:
To this:
I took a bunch of pictures.  It was easy, but I had the use of a media blaster to clean all the rust and crap off, and a special jig to hold the calipers in a vice, and a special tool to seat the seals.
Still have to put them back on the car and see how they work.  My old pistons were pretty poor -lots of pitting.  The old seal were shot - didn't leak, but they were old and wasted.  I am hoping that my left front wheel will no longer lock up before the right front.
New wheels and tires are on the way and I have to install my new rev limiter...almost ready for autocross to start.
Nothing is so bad that you can't make it worse by doing something rash or going berserk.
« Reply #1 on: February 26, 2008, 09:39:46 PM »
Dude!   023 023
Great job!!  ...  I'm impressed.
T.J.
Yippee!
« Reply #2 on: February 27, 2008, 06:44:27 AM »
Don't be impressed....it's not real gold  icon_razz
Just a rattle can of engine enamel I bought at NAPA.  I do hope they work better.  On the driver side one of the old pistons really didn't move much - figured that out when I changed brake pads and couldn't push the piston in.
« Reply #3 on: February 27, 2008, 08:04:39 AM »
Good job TJ, they have to work better than mine.
I have 4 wheel drums or aka "push and pray brakes".
T.J.
Yippee!
« Reply #4 on: February 27, 2008, 02:20:18 PM »
Here's a picture of one of the calipers all cleaned up and put back together - before I pimped my ride and painted it gold.
I am going to run in G Prepared this year - if my tire choice works out anyway.
« Reply #5 on: February 27, 2008, 03:10:54 PM »
Weren't you in HS last year? What are you doing to the car that puts you all the way into the prepared class?
T.J.
Yippee!
« Reply #6 on: February 27, 2008, 05:19:55 PM »
going from this to this:
Changed some other things as well, but tires are the driver since there are no R compound 10" tires.  Yokohoma A032R are available in the right size, but technically not DOT approved in that size.
UPS man brought me new tires today....it was a good smell to open the boxes.
« Last Edit: February 27, 2008, 05:21:55 PM by T.J. » Logged
Oh my....
« Reply #7 on: February 27, 2008, 05:29:47 PM »
can I send you mine?  I could use that work .... I was thinking of just buying new calibers
Who's mounting the tires?  Or more importantly, did you have any trouble finding someone to mount them?  I bought a 10" wheel and tire to use as a spare (the one I have is 12, but the MiniLite clones are 10) and found a warning to only hand mount the tire to the wheel because of the high possibility of damage?!?!  I've never had to dismount a tire (touch wood) on OC.... and I haven't found anyone to replace Mike....
The Captain sends
T.J.
Yippee!
« Reply #8 on: February 27, 2008, 05:54:44 PM »
BJ,
New pistons and seals cost me around $120...that's way cheaper than new calipers, especially the 7.5" ones.
If you want to send yours up here and buy the parts I can rebuild them.
2 of these http://www.7ent.com/detail.cfm?pageid=2566
4 of these http://www.7ent.com/detail.cfm?pageid=1114
2 of these http://www.7ent.com/detail.cfm?pageid=1107
I haven't got the tires mounted yet.  My current tires I had mounted at the Kramer tires down the road.  I am putting the slicks on my 10x6 revolution wheels and getting a new set of 10x5 minators for normal use.
« Reply #9 on: February 27, 2008, 10:22:15 PM »
TJ - Call Chuck at Firestone over by Chesapeake Square Mall about mounting your tires (unless you know somebody). I don't have the number handy. He's a racer and knows his stuff about mounting race tires. Tell him I sent you and he'll help you out.
He'll cuss me later about sending 10" tires his way but I'll tell him it's practice for when I need them. Just kiding, he's good people.
T.J.
Yippee!
« Reply #10 on: February 28, 2008, 08:22:29 AM »
Thanks Roy, that's close to my house.  I'll go there and see Chuck.
« Reply #11 on: February 28, 2008, 08:47:19 AM »
TJ
Nice work restoring those calipers. If you had left them unpainted,I'm sure they would quickly have a layer of rust just from air miosture alone? Does painting them cause heat retention? or is it not that important.
I kinda like the clean look and thought clear coating them would retain a "Like New" look longer.
Nice photos too, is that Photobucket?
T.J.
Yippee!
« Reply #12 on: February 28, 2008, 09:06:21 AM »
Not sure about the heat retention.  I used high temp engine enamel to paint them.  I too liked the cleaned up bare metal look, I just wanted to paint them to keep them from getting all rusty again.
Yep, photobucket.
« Reply #13 on: February 28, 2008, 02:04:28 PM »
Those calipers look wicked nice!  Your car is lookin real good all around, and that new rubber ought to work nicely on the Revos, You'll have to take me for a spin in that monster once the new shoes are on!
T.J.
Yippee!
« Reply #14 on: March 09, 2008, 04:53:33 PM »
TJ - Call Chuck at Firestone over by Chesapeake Square Mall about mounting your tires....... he's good people.
Roy,
Chuck is good people!  I owe you one.
Here's the new tires mounted....
Assuming I can get all this rubber inside my fenders, I'll have a little more rubber for auto-x ing!
Shawn,
My new wheels are a little like Sparks'..they are 10x5 Minator's...I put my old A008's on them...they are an inch skinnier than my revo's---not sure how they will look with my fender flares yet.  The slicks will be just for auto-x.
Pages: [1] 2   Go Up
