You are here: Home arrow Forum arrow Grease Pitsarrow Wheels and Tiresarrow HELP
Welcome, Guest. Please login or register. February 11, 2012, 12:15:15 AM
Pages: [1] 2   Go Down
Author Topic: HELP  (Read 1192 times)
Angelo
Royal Blue For Me!
Tim
« on: March 21, 2008, 03:52:59 AM »
ok people....   215/55 16 on 16x7?  to big for the 2007 cooper?   or should i go with 205/55 16?
Italian Corespondent
accentz
Track Junkie
« Reply #1 on: March 21, 2008, 07:42:51 AM »
I put 225/45/17 with 17 X 7 on my 06 MC. They work just fine but I do have a couple of small issues with them. I had to put 5mm spacers on the front so the tires wouldn't rub the strut. That doesn't hurt anything but you need to put a wheel stud kit on because with the spacers your wheel bolts will only have about 3-4 thread engagment. I have also found that during extreme suspension motion (like agricultural racing) the tire will rub the plastic trim piece on the hood and will pop the rivets holding it on. It's a $2.00 fix.
My thinking is the 215's should be good but unless you drive at the limit of adhesion and need every ounce of traction go with the 205's and you won't have to worry about it.
Roy
78 Austin Mini
06 Justa Cooper
Angelo
Royal Blue For Me!
Tim
« Reply #2 on: March 21, 2008, 08:08:21 AM »
...you need to put a wheel stud kit on because with the spacers your wheel bolts will only have about 3-4 thread engagment....
Is this a difficult task?
...unless you drive at the limit of adhesion...
What do you mean by this?
tnd2
« Reply #3 on: March 21, 2008, 09:07:37 AM »
Nope, easy task! Just make sure you get some good quality studs, or check into the longer lug bolts. Remember you have 14mm not 12mm like us Gen 1's. Good spacers are a must, make sure you spend the $ and get the ones that are drilled to your bolt pattern, 4x100mm, not the universal ones(they suck, hard to keep centered while tightening the lugs down)
Heres a great spacer, H&R, but these are for Gen 1 12mm, so youll need to find something like this but for 14mm
http://www.turnermotorsport.com/html/subcategory_detail.asp?modelcode=Mini&subcat_id=93
and don't get Palo Uber studs, there crap.
I put these on Frank
http://www.turnermotorsport.com/html/detail.asp?PRODUCT_ID=TWH9950 but again these are 12mm, somebody has to have 14mm
TSW has some good stuff, email Jeff and tell him what you have and he'll come up with what you need.
http://www.txwerks.com/servlet/Categories?category=MINI%3AWheel+Accessories&searchpath=19972&start=1&total=13
Oh yea, just wanted to mention we've got Mini envy!
Hope as is well, and looking forward to yall getting back to the states!
Sean the Turd Polisher
I'm one of "those" people that don't own a MINI!
« Reply #4 on: March 21, 2008, 10:39:54 AM »
I've got the TSW lug studs and my only complaint is they have started to rust.  Admittedly I should have taken better care of them, so I would still recommend them.  What I would do is buy the TSW lug nuts, not a slam on TSW, they work great, the just need a special lug socket.  Where as 949 Racing has 17mm tuner lugs that would have coverd more of the stud, thus not letteing the stud corrode.   For me, I like the idea that I can get a 17mm socket anywhere, unlike the special lug key.   Lesson learned from reality.  Texas speedwerks sell the conversion stud kit.. 14 mm into the rotor and 12mm for the  lug bolts.
My Land Cruiser cancels out 2 Prius ... what is the plural for Prius?
Angelo
Royal Blue For Me!
Tim
« Reply #5 on: March 21, 2008, 11:29:32 AM »
Nice Info Guys....   thanks alot!
accentz
Track Junkie
« Reply #6 on: March 21, 2008, 11:52:46 AM »
Sorry, the "limit of adhesion" AKA the "edge of traction" is a racing term that refers to the amount of traction any given tire can give. It's that razor sharp edge between where the tire has the maximum amount of grip to the road and the point where the tire says "I'm done" and sends you off into the weeds. It can be a very thin line depending on the type of tire.
I could go on for days about it but I'll try not to bore you. Let's just say it's every racers dream to live there the entire time their on track. Although it never happens.
Roy
78 Austin Mini
06 Justa Cooper
« Reply #7 on: March 21, 2008, 11:54:39 AM »
I feel I'm pretty good at the "weeds" part.....  icon_evil
Angelo
Royal Blue For Me!
Tim
« Reply #8 on: March 21, 2008, 12:40:44 PM »
None of these F*****'s will ship to APO....  i hate all of them
awood279
« Reply #9 on: March 21, 2008, 12:42:10 PM »
So have them shipped to us and we'll then ship it to you.  023
Angelo
Royal Blue For Me!
Tim
« Reply #10 on: March 21, 2008, 01:16:28 PM »
Would you do that if i needed?
ok so Spacers?  100% nessicary?
awood279
« Reply #11 on: March 21, 2008, 01:25:34 PM »
of course silly!! 045
obehave
« Reply #12 on: March 21, 2008, 01:48:30 PM »
I've been running 215-50 16s for years. Very close to stock diameter. Just .1% taller than stock.
Your 215-55s would be too tall. The 205-55s would be closer to stock. Too large by just 1.8% in diameter.
Zero fitment issues using stock X-Lites(+48 ET), NZO wheels with stock offset and SSR Comps running +42 offset.
BF Goodrich Traction TAs. Never was a Goodrich fan until I started running these tires. Ask Angela. She autocrossed my old set. 023
obehave
« Reply #13 on: March 21, 2008, 02:03:26 PM »
I run the ProMINI studs. No rust in over a year. he H&R spacers are great, running them too. You shouldn't need them for anything under 225 width on the stock offset.
Any machine shop worth 2¢ can punch out the holes in the spacers for about $20. Hell I could do it on a drill press. Of course the bit would run you $20  icon_lol
Angelo
Royal Blue For Me!
Tim
« Reply #14 on: March 21, 2008, 02:15:07 PM »
ok Everbody have decided on 225/45/16's on 16x7's and i need to know if i HAVE to have spacers and new lugs cause i would prefer not to have to do that
Pages: [1] 2   Go Up
