You are here: Home arrow Forum arrow Grease Pitsarrow Wheels and Tiresarrow HELP
Welcome, Guest. Please login or register. May 23, 2012, 03:58:17 PM
Pages: 1 [2]   Go Down
Author Topic: HELP  (Read 1329 times)
accentz
Track Junkie
« Reply #15 on: March 21, 2008, 03:12:34 PM »
My quess would be YES.
Roy
78 Austin Mini
06 Justa Cooper
obehave
« Reply #16 on: March 21, 2008, 03:16:06 PM »
ok Everbody have decided on 225/45/16's on 16x7's and i need to know if i HAVE to have spacers and new lugs cause i would prefer not to have to do that
Need to know the wheel offset. Without that you can't/won't get an accurate answer.
If your car isn't lowered and you are running stock offsets it'll be damn close on the inside of the tire. If you go 5mm spacers you will then need to get 10mm longer bolts or studs( you may find 5mm one but I couldn't). You will then almost certainly rub on the outside of the tire slightly. Probably just under full load of gas, 2 people or more, and spirited cornering involved. Just in the rear. Yes get 4 spacers.
Wheel studs are nice but remember that'll force you to change wheel locks or do like I did and use 3 studs and 1 lock but good luck finding a lock bolt that is longer than stock spec.
Angelo
Royal Blue For Me!
Tim
« Reply #17 on: March 21, 2008, 06:04:33 PM »
ob,
here are the tires...  16x7  MOTEGI RACING SX7 Flat Black w/Mach Lip\
what do you think?
Italian Corespondent
obehave
« Reply #18 on: March 21, 2008, 09:22:37 PM »
ob,
what do you think?
I like them and Motegi is good bang for the buck stuff. The downside is the only offset I can see, in a quick web look around, is +35. Running 225s you will get some rubbing on the outside. Shouldn't be too bad if you're not lowered but I can almost guarantee they'll rub some. The nice part is the tire will wear out exactly what needs to go icon_lol
If you're lowered I can't speak from experience but it'll obviously rub more. How much I can't say.
You'll love the 225s and that size(225-45x16) is pretty close to stock. Speedo will read high by 1.8%
Very close to the 205-50 16s I ran for a bit. An indicated 60mph will be close to an actual 56mph since most MINI speedos read fast anyway.
Pics will be a must
Angelo
Royal Blue For Me!
Tim
« Reply #19 on: March 22, 2008, 03:40:51 AM »
ok what about this combination will this work with out rubbing or the need for spacers and new lugs?  i just dont want to have to buy to much stuff to get a better grip i will do all that when we get home for autox  you know?
15x6.5 MOTEGI RACING SX7 Flat Black w/Mach Lip
205/55ZR15 Yokohama S.drive Blackwall
Sean the Turd Polisher
I'm one of "those" people that don't own a MINI!
« Reply #20 on: March 22, 2008, 07:54:25 AM »
Quote
Stock 195/55/16
Diameter 24.4 inch
Width  7.1
205/50/16
Diameter 24.1
Width 7.2
Increase Tread Widthon car .2"
215/55/16
Diameter  25.3
Width  7.9
Increase Tread Widthon car 1.6'
225/50/16
Diameter 24.9"
Width 7.6"
Increase Tread Widthon car 1.0"
225/45/16
Diameter 24.0
width  8.0
Increase Tread Widthon car 1.8"
I run on the street..205/50/15  7.6" wide, and on the track 225/50/16 at 9.0" wide.  The street tires are Falken Azenies, Tire Rack doesn't carry them, but that's fine, the tires your looking at are great.  The Track tires are Kuhmo 710 R Compound Competition tires and stick like glue.  Especially considering they give me 3.6" more tread.  But I digress.
I think you're more apt to need spacers for the 15's than the 16's.  I run a 5mm spacer on the front, ($8 Pepboys) for the 15's to clear the caliper due to the shallow offset.  Shallow offset gives you that "Deep Dish" look.  My 16's are stock size 16x 6.5 with  a size of 215/40/16 with no spacers & no rubbing.  (Apologize for the size error in the above quote.)
Now, studs, lugs and locks.  I run the studs only because I change tires at least twice a month sometimes 4 or 6 times a month, so the convience is worth the $100 bucks or so. It might be alittle more but you get the point.
I can poke around on NAM to see if you orginal tire size 225/45/16 needs spacers or if they are "self trimming" for the wheel arches.  Or go with the 215/40/16's, no rubbing, no spacers.
I recall driving obehave crazy when I was buying rims & tires with questions and concerns, so we all understand your concerns too, I know everyone at HRMINI will help!   I'll even get them test fitted here in the US for ya!!  And as far as shipping....... buy what you want ship 'em to my house, I'll have 'em mounted, balanced and shipped to your APO address.
Have you looked at 18racing.com  ? some cool stuff and some great new colors.   039
 066
My Land Cruiser cancels out 2 Prius ... what is the plural for Prius?
Angelo
Royal Blue For Me!
Tim
« Reply #21 on: March 25, 2008, 03:16:05 AM »
Any last ideas  trying to nail this down before the end of the week
Angelo
Royal Blue For Me!
Tim
« Reply #22 on: April 14, 2008, 03:11:17 PM »
Tools in hand to put things in place.
Tires in place.
Look at the tread.
Wheels that are as mean as the Ring.
« Reply #23 on: April 14, 2008, 05:19:06 PM »
Don't you be using all that tread up before August!!!!
accentz
Track Junkie
« Reply #24 on: April 14, 2008, 06:48:50 PM »
Don't sweat it. The less tread the better.  023
That is unless it's raining.
Roy
78 Austin Mini
06 Justa Cooper
Angelo
Royal Blue For Me!
Tim
« Reply #25 on: April 15, 2008, 12:05:03 AM »
got to break them in before the ring....  DUH!
Pages: 1 [2]   Go Up
