You are here: Home arrow Forum arrow Welcome To Hampton Roads MiNi!arrow Everything MINIarrow Will it EVER end??? Help/advice needed...
Welcome, Guest. Please login or register. November 21, 2008, 01:22:59 PM
Author Topic: Will it EVER end??? Help/advice needed...  (Read 126 times)
Uber Blu
« on: May 10, 2008, 04:52:36 PM »
Schultze came home Tuesday afternoon...YAY!!!  026
I've taken him on a few shakedown cruises since then and have noticed a few things which are being handled by the collision center.
However, one issue that persists & possibly requires a visit to CF is the fact that both the tire & DSC warning lights remain lit!  Those are the same two warning lights that immediately lit up after the accident happened.  101
Does anyone know if it's possible to reset those warning lights without needing a trip to CF?  (Yes, I've pressed the button that's next to the e-brake, but the light stays lit no matter what!)
I have to limit the amount of time I drive Schultze because when I went off the road and hit the ditch, it bent the exhaust hangers and the exhaust tip is starting to melt/bubble the new rear bumper.   104  The collision center is making arrangements with arrangements with a muffler shop to have it fixed.  The initial solution is to have the muffler shop cut the muffler & a short length of pipe leading to the muffler and weld into place a downward-angled pipe leading to the muffler.  The end result...as they've described it...will lower the exhaust tip approx 1/2"-3/4" below the curved opening on the rear bumper.  Does this sound like the proper solution to the problem?  Oh...and they plan on removing the damaged bumper, repairing it & repainting it.  However, since the bumper cover itself is plastic, I'm concerned that it won't look right...what is used to repair melted plastic?  Is there such a thing as "bondo for plastic"?
Does anyone have (or can recommend) a heatshield product that I can tuck between the exhaust tip & the bumper until the repair is done by the muffler shop?
I'm doing my best to make sure all these repairs are completed as soon as possible...I really want to go to Kilmarnock next weekend!!!
Became a proud 1st time MINI owner on 01/13/07!!!
'06 HB/W, #1, #2, #3, #4 (Prod. date: 10/20/06)
MINI #15 at GWR 06/10/07
Bitten by the mod bug!
« Reply #1 on: May 10, 2008, 10:44:15 PM »
  I would make them replace whatever is bent on the exhaust system rather than try to throw a bandaid on it. Insurance is supposed to pay to put the car back into pre-accident condition by replacing/repairing parts, not jury-rigging things and IMHO chopping and re-welding on the exhaust system is jury-rigging.
   I'm not sure what they would use to fix the melted spot on the bumper cover.  I'm reasonably sure that it isn't regular bondo though.  That dries hard as a brick and anything that they would use on it would have to shrink/expand at the same rate as the plastic would with heat/cold.  I do know that body shops can flawlessly repair bumper covers though.   My suggestion is to park Schultz until they get EVERYTHING right lest it damage something else.   icon_frown
"Pity for the guilty is treason to the innocent." - Richard Rahl
"Justice is not the exercise of hatred, it is the celebration of civilization." - Richard Rahl
« Reply #2 on: May 13, 2008, 08:20:22 AM »
It saddens me to hear that the exhaust wasn't correctly repaired along with all the other related damage. Typically, what is done in your case, would be to remove and replace the exhaust from the bent area back to what is undamaged. Then replace it with as close to factory exhaust tips or aftermarket tips that you may have installed yourself to return it to pre-accident specs. Leaving the exhaust tips that close to he bumper cove is simply put, stupid.
As for repairing the replaced new bumper cover, yes it can be done with the proper plastic repair process, and most body shops have this available. However, you "had" a new cove put on, and a new cover is what you should get. I would have it replaced bythose who screwed it up in the first place and let them worry about the loss of profit.
Repainting the cover at this point shouldn't cause any color match problems either, assuming of course that the very same shop does it again. If you like, that is if you still have my number, give me a call and I'll see if I can give you some quicker responses to any problems you may encounter.
As for those lights coming on again, that will require a trip to CF, as I'm certain it will need to be reset.
