You are here: Home arrow Forum arrow Grease Pitsarrow ICEarrow Stuck Window Solution
Welcome, Guest. Please login or register. May 24, 2012, 12:11:36 AM
Author Topic: Stuck Window Solution  (Read 2634 times)
Our03Mini
« on: July 22, 2008, 08:28:06 AM »
I was having issues with my passenger side window not working. Thought I was going to have to spend money to get it fixed. Found this solution on another message board (mini2.com). I thought I would share the solution. I couldn't believe it, it actually worked  038
Solution:
1. With the car in aux or on -- sit in the passenger seat with the door open.
2. Press and hold the window switch up
3. Immediately, while holding the window up toggle -- with your fist -- punch / hit three inches above the large speaker -- three times. <bang bang bang>. Don't be easy on your MINI.
4. Let go of the toggle switch.
5. Press and hold the toggle switch up for 5 seconds.
6. Lower the window completely.
7.With the door still open, raise the window completely. The window should have now "re-indexed" itself.
Sean the Turd Polisher
I'm one of "those" people that don't own a MINI!
« Reply #1 on: July 22, 2008, 10:28:23 AM »
That is just plain cool.   icon_mrgreen
My Land Cruiser cancels out 2 Prius ... what is the plural for Prius?
Dave
« Reply #2 on: August 05, 2009, 03:10:41 PM »
I have been having the same problem off and on with my passenger side window. I'll save this info and give it a try the next time this happens. Mine has always fixed itself so far, but it usually seems to take a day  093
03 MCS Electric Blue/W.  Alta CAI, Craven 15% S.C. Pulley, Screamin' Deamon Coil Pack, Magnecor comp. plug wires, Alta 2.5" V2 Catback exhaust, Alta air diverter and oil catch can.
eagle65
« Reply #3 on: December 18, 2010, 06:54:37 AM »
I just stumbled on this. Does anyone know if this works on the driver's window? I've been having re-occuring problems since June. Once a dealer reset it, the other times it fixed itself, but it may take weeks!
Thanks.
Dave
« Reply #4 on: December 18, 2010, 11:52:21 PM »
 017 017 017 My sticking window has always been the passenger side window, but this trick has worked for me several times. Why not give it a try....Don't be shy either, give it a good hit !  and please post your results.
« Reply #5 on: December 30, 2010, 04:16:35 PM »
I believe I had to do this once or twice with my old '02 MCS.  Yes, it does work.
Hankfrum
Daniel
« Reply #6 on: December 30, 2010, 04:45:19 PM »
you know i dont know if banging on the door really is a good idea. couple of weeks ago i closed my door rather harshly(wind combined with me closing) and it blew my speaker. i took the door apart and its just a cheap paper cone. hte speaker was fine before the incident. matter fact hwen i got in the car and started driving you could hear it rattle. just my 2 pennies.
DS/B, 15%pulley, M7 STB, Alta 19mm Rear Sway Bar, NGK BRK7 plugs, Invidia Exhaust, Alta CAI, Prosport Boost Gauge
THTGUY
« Reply #7 on: December 30, 2010, 05:40:08 PM »
It has to do with the electric window motor getting stuck.  You want to make sure to tap at your door exactly where it's located.  There should be a few threads floating around on NAM that discuss this topic.
