You are here: Home arrow Forum arrow Grease Pitsarrow Gearheadarrow Starter?Alternator? not sure
Welcome, Guest. Please login or register. November 20, 2008, 10:21:30 AM
Pages: 1 [2]   Go Down
Author Topic: Starter?Alternator? not sure  (Read 204 times)
Trish
The ORIGINAL Big Red
boop-oop-ee-doop
« Reply #15 on: September 14, 2008, 08:21:56 AM »
 023
2005 HyperBlue Convertible
VBCHCHK
« Reply #16 on: September 15, 2008, 03:15:13 PM »
Glad the battery was the problem.  I just changed out my stock battery in my '02 MCS this past Spring.  Got about 5 1/2 years out of it.  My friend at a dealership said the battery amp rating was a bit low when he tested it, which I was attributing at the time to start problems.  It turned out to be crappy Hess gas, but I'm still glad I changed it at the time.
Usually, a short battery life means the alternator may not be charging it back up (i.e. bad voltage regulator inside).  However, since two of you only received three years of life, maybe Mini had a bad batch of batteries.
'02 MCS, Silver/Gray, GReddy A/F & Boost gauges, Koni Stage 3 Kit susp kit, Alta solid casters, Alta f/r endlinks, Hotchkis r u/l ctrl arms, R Dynamics f strut brace, Cobalt r strut brace, skid plate, BBS RK rims, Kicker spkrs/amp
Pages: 1 [2]   Go Up
