You are here: Home arrow Forum arrow Social Sidearrow Photo Galleryarrow Angel Eyes and Driving Lights
Welcome, Guest. Please login or register. February 08, 2012, 07:51:09 PM
Author Topic: Angel Eyes and Driving Lights  (Read 378 times)
« on: June 13, 2010, 12:54:01 PM »
I installed my Angel Eyes lights and driving lights yesterday.  Took all day.  The Angel Eyes were the easy part.  As for the driving lights, I had to drill quite a few holes in the bumper and mounting brackets.  The cool thing is outer bracket is behind the license plate.  You can hardly see it.
I still have to do the wiring for the driving lights, though.  Not sure how I will get them hooked up just yet.  I'm gonna see if I can use the relay button setup from my old '02 MCS.  Otherwise, I will just use the one that came in the kit.
« Last Edit: June 13, 2010, 01:01:53 PM by JumpingJackFlash » Logged
Hankfrum
Daniel
« Reply #1 on: June 13, 2010, 03:32:44 PM »
Nice!...I think I'm a go on those angel eyes. Maybe a better look for what I'm trying to do. Did some looking and haven't found i light yet that I'm happy with. The silverstars just don't look bright as i want.
DS/B, 15%pulley, M7 STB, Alta 19mm Rear Sway Bar, NGK BRK7 plugs, Invidia Exhaust, Alta CAI, Prosport Boost Gauge
THTGUY
« Reply #2 on: June 14, 2010, 09:18:33 PM »
All done!   038
In my research, I was reminded the daytime running lights are a low-power version of the high beams.  Had I used that circuit, the lights could be turned on without even using parking lights (provided the switch was turned on).  As a result, I had to wire the driving lights directly to the battery (which is about the same thing, except I am bypassing the ignition circuit).  The panel below the steering wheel was two-layer hollow plastic.  Thankfully, they had a provision for the OEM driving light switch (like the '02 MCS had).  I just drilled that out and put the switch there.   080
2006 MCS - Lights on - Pic1
2006 MCS - Lights on - Pic2
