GNOM1E
Mini Convert
Offline
'11 Ice Blue MCC
« on: June 30, 2010, 02:37:31 PM » |
I'm coming out of lurk mode for a vent, and a PSA for other '09 convertible owners:
After some intermittent rattles in my '09 convertible I got tired enough last week to do some more in depth checking. I realized that there is a gap between the soft top & weather stripping on the rear passenger side. After much struggle with work schedules (I work 12hr shifts!!) I managed to get Phlppr into Checkered Flag today.
Imagine my surprise when Frank called to inform me that yes, there is indeed a gap in the soft top at the weather strip, and it's a KNOWN problem in '09 convertibles! Apparently they have only recently(?) discovered a broken plastic bracket that allows the soft top to gap and are working on creating a fix kit for it. In the meantime, yes, it could leak down into the boot when it rains :(
I'm on the list for the fix when it is finally available. You can bet I'll be on the phone every week to Frank. I also had Frank repeat to me 3 TIMES that any damage from leakage would also be a covered repair!!
I'm a little frustrated with myself for not getting more detective sooner, tho I'm not sure what good it would have done. And no, a garage isn't an option for storage, especially when I'm working 12hr shifts. I'm hoping that there is minimal, if any damage, from leaking and that Frank/CF doesn't fail me on repairing that when the time comes.
---- Lisa (aka: Gnom1e, Bookworm, FunShine Bear, All Knowing Mommy Goddess)
"Love all, trust few, do wrong to none." ----William Shakespeare
« Reply #1 on: June 30, 2010, 02:42:53 PM » |
You would think that the least they could do is offer the free use of a waterproof Mini car cover until the repair is available
 03 MCS Electric Blue/W. Alta CAI, Craven 15% S.C. Pulley, Screamin' Deamon Coil Pack, Magnecor comp. plug wires, Alta 2.5" V2 Catback exhaust, Alta air diverter and oil catch can.
« Reply #2 on: June 30, 2010, 03:29:07 PM » |
Until you can get your MINI in for service, cover the affected area with a plastic bag, then use some of that adhesiveless tape. It's blue in color and is used to do carpentry work. Someone should be able to help you find it at a Lowe's or Home Depot.
« Reply #3 on: June 30, 2010, 03:36:49 PM » |
Just a thought, maybe check with Crown and see is they have any experience with that problem.
Dale Blankenship Poquoson, VA 09 Laser Blue Clubman S Wife thinks it's hers! 07 Mellow Yellow Cooper S Of course son thinks it's his! Guess I need a third MINI!
« Reply #4 on: June 30, 2010, 03:37:31 PM » |
Careful with the tape, it could leave residue on the top.
ALWZ OPN
"The MINI Cooper S Convertible is Always Open."
Offline
Kevin Cochran (09 ICY MCS Cabrio)
« Reply #5 on: June 30, 2010, 08:12:29 PM » |
Thanks for the PSA!!! I have the broken plastic bracket too, but have luckily (knock on wood) not had any leakage down into the boot. I recently had my MINI in for a broken piece of the trim on the top and wondering if I should be surprised that this broken plastic bracket and known problem was not mentioned to me by Frank???
"Chrome Bonnet Scoop, Boot Latch & Interior, DDM Works-RIS (Race Intake System), K&N Filter, CravenSpeed- FLEXPOD GPS Mount, STD's (Strut Tower Defenders), Stubby Antenna, Tow Hook"
GNOM1E
Mini Convert
Offline
'11 Ice Blue MCC
« Reply #6 on: June 30, 2010, 08:15:33 PM » |
From the way he spoke this is something that has only recently come up. He didn't really give a time frame but did indicate that he had a very short list of owners to notify when the fix becomes available. I would call him and mention that you read about it HERE and get your name on the list also!
« Reply #7 on: July 02, 2010, 11:52:46 PM » |
I double-checked with my brother. It's called painter's tape and is not supposed to leave a residue.
GNOM1E
Mini Convert
Offline
'11 Ice Blue MCC
« Reply #8 on: September 01, 2010, 09:05:53 PM » |
Back out of lurk mode to let y'all know that Phlppr had her top repaired today! I am now of the opinion that there is no "formal" recall on this. Just a known issue and "oh, yeah, there's a fix if you've got the problem".
I do have to say, tho, that I was very impressed with the way CF handled it all today. Originally they said it would take a couple days. So I dropped off early this morning, picked up the loaner (you know... I'm so regretting not buying an "S" to begin with...). got the call from Frank about 2 that Phlppr was all fixed up and ready to come home!!! Pleasantly surprised (even if I didn't get a chance to really give that Grey "S" a good work out).
So, if you think you have a broken bracket on the interior of your '09 soft top... there is now a fix available for it.
« Reply #9 on: September 08, 2010, 08:39:03 AM » |
Glad to hear it's fixed.
