HzBBlur
SOAR143
Offline
« on: August 10, 2010, 06:57:03 PM » |
2009 MCSHzB/B, CWP, PP, "BLUR" Perf: DoS CAI Susp: Alta 19mm Rear Sway Bar Int: Rear Seat Delete Ext: VA Legal Tint w/ sun strip, 16" Gunmetal Rota RB, Dunlop SP Sport 7000, Future: Lowering Springs
Offline
« Reply #1 on: August 10, 2010, 06:59:46 PM » |
There is a speedometer calibration place to the right of Haynes furnature on VA Beach Blvd, not too far from Checkered flag MINI. I don't think they actually make the corrections, but they give an official account for how far off your car is. I think you need a programmer to make the changes once you know how far off you are.
Are you coming to the Pub tomorrow night? Its a great time!
2012 Countryman "Mickey"
« Reply #2 on: August 10, 2010, 09:22:08 PM » |
There is a place not far from my shop in Hampton that does calibrations. Pretty neat to watch too.
And if you could make our dinner at the Pub Hampton, you'd have a good time. Not that I can make it, I'll be busy announcing at Langley Speedway. Especially since it won't rain on a damn Wednesday any more!
Dale Blankenship Poquoson, VA 09 Laser Blue Clubman S Wife thinks it's hers! 07 Mellow Yellow Cooper S Of course son thinks it's his! Guess I need a third MINI!
Offline
« Reply #3 on: August 11, 2010, 03:56:47 AM » |
I don't know about the 2006 and older but the 2007 and newer cars can't be calibrated according to CF. Minis need to have all 4 wheels running at the same speed or the computer goes ape.
Jeff "Mercy is a contingency plan devised by the guilty in the eventuality that they are caught." - Kahlan Rahl
HzBBlur
SOAR143
Offline
« Reply #4 on: August 11, 2010, 08:12:52 AM » |
Thanks Fam! Not sure if I can make it to the Pub, we have dinner plans at Capt Georges tonight. I'd be crazy to stand between my man and his Seafood. Lol
If I can sweet talk him into it I will. Thanks for the info.
HzBBlur
SOAR143
Offline
« Reply #6 on: August 11, 2010, 08:12:04 PM » |
Well, I have to go to court for a 85/55 speeding ticket. Gotta get an official reading.
Offline
« Reply #7 on: August 12, 2010, 02:33:04 AM » |
Hz.... I did that dance with a 58 in a 25 ( in a curve)..... judge never even considered the calibration report. Had an attorney and after an appeal, had it reduced to 10 over.
AFAIK, 30 over is wreck less and may have jail time... have you spoken to a lawyer?
Good luck with all this...
« Reply #8 on: August 12, 2010, 09:20:44 AM » |
A really easy way to calibrate your speedometer is to use a GPS to measure your speed.
Kurt, unfortunately, the odometer directly relies on the speedometer to determine miles driven.
« Reply #9 on: August 12, 2010, 11:13:47 AM » |
Just think, if the speedometer is reading a bit fast, that means the miles rack up faster as well. Meaning you'll be out of warranty sooner. Coincidence? .........
« Reply #10 on: August 12, 2010, 02:19:04 PM » |
Well, Dale, I've already had that discussion before. Several times on NAM and abroad. Different claims say the speedometer can vary as much as 10%. My research has shown that it's done to force people to drive slower and help save lives. The downside is just as you stated; you go out of warranty faster.
Both my old and new MINIs vary by about 7%. At 50 MPH on the speedo, I'm only doing 46 MPH. At 75 MPH on the speedo, I'm only doing 69 MPH. Calculating a 7% deviation, that means I would go out of the extended warranty with only 46,500 miles. So, I decided to accept that I would be satisfied if nothing occurred once I crossed the 53,500 mile mark on the odometer.
Two factors that affect your speed are tire size and tire wear. Usually it's the former that creates a variation. Many car manufacturers know people like putting larger rims and tires. The negative deviation helps make up even for that. Another downside is the negative deviation also is in favor of the law, as you cannot argue your speedo was too low (which would be a positive deviation). Unfortunately for the 85/55, you are probably going to find out your speedo actually reads 91 MPH.
« Reply #11 on: August 12, 2010, 04:22:47 PM » |
I'd probably leave that one out.
Offline
« Reply #12 on: August 12, 2010, 05:15:57 PM » |
Well, I think I am going to have to agree with the post I linked earlier. I did a short 60 mile test of the odometer and speedometer verse the GPS. On average the speedometer read 3-5 MPH higher than the GPS speed, however, the odometer only varied from the GPS on the two occations in which I traveled through the tunnels and lost GPS signal. And then it was only by .1 mile each time. Once I cleared the tunnel, the difference remained the same once again and the odometer continued to track exactly with GPS. This leads me to believe the post that the sensor that feeds into the computer is the same, but the processing for speed and miles is different. I know in the past with cable driven speedometers it was a direct correlation between miles and speed, but I think in the computer age things have changed. I plan to test it further this weekend on a longer run.
« Reply #13 on: August 12, 2010, 05:41:07 PM » |
Maybe you should look into a Radar Detector. A lot of us have them.
Offline
« Reply #14 on: August 12, 2010, 06:29:40 PM » |
Maybe you should look into a Radar Detector. A lot of us have them.  Beltronics STI Driver for the win!
