You are here: Home arrow Forum arrow Welcome To Hampton Roads MiNi!arrow Everything MINIarrow Broken Oil Dip Stick
Welcome, Guest. Please login or register. February 10, 2012, 02:55:19 PM
Author Topic: Broken Oil Dip Stick  (Read 585 times)
SKARGO
Dave
« on: August 25, 2010, 02:57:55 AM »
Last Sunday I went to check the oil level on my '03 R53, and the dip stick broke off as I was pulling it out of the tube  093 Lucky for me the broken end was outside the tube, and I was able to pull the rest of the dip stick completely out  038  The dip stick is a 1/8" dia. piece of fiberglass rod with a black coating of plastic/rubber material which I guess is to protect the fiberglass from the oil and heat. I found this black coating to be cracked in MANY places along the length of the dip stick, allowing engine oil to get to the fiberglass rod, which I suspect weakened it to the point of breaking. Anyone else ever had this happen ???  Good news is that Moss Mini has a BMW OEM dip stick in their inventory. I ordered one online Monday morning and got it on Tuesday. $27.80 damage including tax and shipping. Suggest everyone check their dip sticks for cracks.
Pull it out, bend/flex it and look for cracks along the length of it. If it were to break off inside the dip stick tube, it might be a real pain to remove the tube and make the repair. I was lucky  080 Might be a really good idea to have a look at those dip sticks before heading up to Moss this weekend, you may need a new one and not know it yet.
03 MCS Electric Blue/W.  Alta CAI, Craven 15% S.C. Pulley, Screamin' Deamon Coil Pack, Magnecor comp. plug wires, Alta 2.5" V2 Catback exhaust, Alta air diverter and oil catch can.
« Reply #1 on: August 25, 2010, 03:04:38 PM »
Good catch Dave!
Great advice too! Wonder if it's a R53 thing or if the later R56's may have the same issue?
Bugs
« Reply #2 on: August 25, 2010, 04:11:16 PM »
Mine broke in the old '02 MCS.  I bought the aftermarket one, but it ended up bending to the shape of the oil tube.  I'd rather stick to the OEM one, even though that little honey-comb measuring tip is weird looking.
sparke1975
Just plain ole Me!
Kurt
« Reply #3 on: August 25, 2010, 05:06:26 PM »
Hey Dale, If I remember right ours has a stiff cable with a bob at the end for checking the oil
"Tiberius"
09 Laser Blue MCSC, Alta Catback, Alta Sway Bar, Defenders of Speed CAI
« Reply #4 on: August 25, 2010, 10:37:45 PM »
Check the oil?? We supposed to do that? 102
