since the pcv recirculation line enters the intake before the turbo is it possible that that particular design was implemented to lubricate the turbine in the turbo? could eliminating that cause premature turbo failure? this has me super worried because i just bought a 07 mcs turbo this tuesday, knew i should have gone with the 04 jcw.
The two hoses are from two cylinders each of recirculated gases. It would probably be poor to assume a turbo would be lubricated by them. There is no way to guarantee any oil would be mixed in. Per
this diagram at RealOEM, the turbo has its own lubrication tube (#6).
Best advice is to change your oil every 5K miles or so. Get with the dealership, or your preferred Eurosport shop, and have the engine get a carbon buildup cleaning. Some members here are getting oil catch cans installed in their R55/R56/R57s. While this will not eliminate the carbon buildup in the turbo, it will cut it down.
