Skip to content
Skip to main navigation
Skip to 1st column
Skip to 2nd column
Home
Calendar
Forum
History
Links
Member Index
You are here:
Home
Forum
Grease Pits
Wheels and Tires
Tire Pressure
News
Home
Help
Search
Calendar
Login
Register
Welcome,
. Please
login
or
register
May 25, 2012, 02:45:45 AM
1 Hour
1 Day
1 Week
1 Month
Forever
HRMINI
Grease Pits
Wheels and Tires
Tire Pressure
Pages: [
1
Go Down
« previous
next »
Author
Topic: Tire Pressure (Read 423 times)
speedfrk
Offline
Tire Pressure
on:
April 14, 2011, 03:01:19 PM »
My door tag on my my 07 MCS says 38psi cold for all four tires. Is that the optimum pressure, or is there a better setting for ride quality and tread life? I'm currently running a set of new Conti Extreme Contact DWS 205/45/17 standard tires(non run flats). When I picked my car up from from having them installed I checked the pressures a few days later only to find all four tires set to the max cold pressure of 51 psi. I immediately dropped them down to 42 in the front and 40 in the rear. The car feels a lot better now. I'm relying on the experience you all have had with tire pressures on these cars. Thank you.
Offline
Re: Tire Pressure
Reply #1 on:
April 14, 2011, 05:34:46 PM »
Everyday driving around I usually run my tires at 35#. If I'm going out on a run I might pump the front up to 38# or so to help the keep from rolling under in the corners.
Offline
Re: Tire Pressure
Reply #2 on:
April 14, 2011, 06:17:40 PM »
I start mine off (cold) at 32psi. For Auto crossing I run 42-43 front and 40-42 rear. It really depends on the ride that your looking for.
Mike
Offline
Mike
Re: Tire Pressure
Reply #3 on:
April 14, 2011, 06:48:42 PM »
I usually run 35-36 psi cold.
Offline
Re: Tire Pressure
Reply #4 on:
April 18, 2011, 08:25:41 PM »
I typically do 38 PSI on tires rated at a maximum of 50 PSI. With full-size tires, you should actually pressurize them based on the percentage of weight that is on each one compared to its maximum rated load. However, in my experience, this rule does not exactly apply to tires that have a lower profile. You want to maintain enough pressure to keep the small sidewalls shaped fairly well.
The minimum I have ever put in is 36 PSI under any conditions.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
Welcome To Hampton Roads MiNi!
=> Introductions Please
=> Members Profiles
=> Everything MINI
=> Off Topic Chat
=> Site Feedback
=> Rants and Raves
MINI's on a Ferry 3 March 24, 2012
=> MINI's on a Ferry 3, March 24, 2012
Grease Pits
=> Detailing-washing/waxing/detailing
=> Mods - Engine, chassis and otherwise
=> AutoX
=> Exterior Mods
=> ICE
=> Wheels and Tires
=> Mini Classics
Social Side
=> Event Planning
=> Photo Gallery
=> National & Larger Events
=> Hampton Roads
=> Northern VA/DC/MD happenings
=> North Carolina happenings
Market
=> MINI Stuff For Sale
=> Wanted
=> Junque For Sale
=> Vendors
Off Topic
=> Jokes
Loading...
