You are here: Home arrow Forum arrow Grease Pitsarrow Wheels and Tiresarrow Tire Pressure
Welcome, Guest. Please login or register. May 25, 2012, 02:50:30 AM
Author Topic: Tire Pressure  (Read 423 times)
speedfrk
« on: April 14, 2011, 03:01:19 PM »
My door tag on my my 07 MCS says 38psi cold for all four tires. Is that the optimum pressure, or is there a better setting for ride quality and tread life? I'm currently running a set of new Conti Extreme Contact DWS 205/45/17 standard tires(non run flats). When I picked my car up from from having them installed I checked the pressures a few days later only to find all four tires set to the max cold pressure of 51 psi. I immediately dropped them down to 42 in the front and 40 in the rear. The car feels a lot better now. I'm relying on the experience you all have had with tire pressures on these cars. Thank you.
« Reply #1 on: April 14, 2011, 05:34:46 PM »
Everyday driving around I usually run my tires at 35#. If I'm going out on a run I might pump the front up to 38# or so to help the keep from rolling under in the corners.
BabyBMW
See ya
« Reply #2 on: April 14, 2011, 06:17:40 PM »
I start mine off (cold) at 32psi. For Auto crossing I run 42-43 front and 40-42 rear. It really depends on  the ride that your looking for.
Steve, Keep the Shiny side up
Mike
Mike
« Reply #3 on: April 14, 2011, 06:48:42 PM »
I usually run 35-36 psi cold.
« Reply #4 on: April 18, 2011, 08:25:41 PM »
I typically do 38 PSI on tires rated at a maximum of 50 PSI.  With full-size tires, you should actually pressurize them based on the percentage of weight that is on each one compared to its maximum rated load.  However, in my experience, this rule does not exactly apply to tires that have a lower profile.  You want to maintain enough pressure to keep the small sidewalls shaped fairly well.
The minimum I have ever put in is 36 PSI under any conditions.
