You are here: Home arrow Forum arrow Welcome To Hampton Roads MiNi!arrow Everything MINIarrow First Mod Advice
Welcome, Guest. Please login or register. May 25, 2012, 04:22:17 AM
Author Topic: First Mod Advice  (Read 886 times)
SMLNFST
« on: June 15, 2011, 10:00:29 AM »
Hey guys  100
I am about ready to start the modification process on my 2007 R56, just kinda wondering if anyone has any advice on what my first mod should be. I know I want a heat shield for the turbo but thats not really a performance mod so any suggestions are welcome.  icon_lol
-Ronnie
2FUN4ME
Kathy
It's not a car; it's a lifestyle
« Reply #1 on: June 15, 2011, 10:48:06 AM »
I recommend against a heat shield for the turbo.  Mini has one that just covers the oil inlet to avoid overheating.  I don't know all the technical stuff but after installation, my heat shield esd actually slightly touching the unit and MINI recommended I remove it.  I also know of someone who had turbo failure due to the heat retention of the heat shield.  Course there are those that still have it on their cars with no reported problems.  It was not worth the risk to me.
  Apollo is my 09 MCSa MY/B #1, #3 Tuscan leather, oak trim & wheel.   My hubbie and I met thru HR MINI!
SMLNFST
« Reply #2 on: June 15, 2011, 11:33:29 AM »
really? hadn't thought about that problem. thanks for the advice,  although I am really worried about my hood scoop getting to hot and warping, which it has already started to do.
MINI OOP
« Reply #3 on: June 15, 2011, 01:02:31 PM »
Dealers are placing a heat shield of sorts at the scoop underside open area.  Not sure if it's being done per your request or after the scoop actually warps, give them a call.  It's the same sheld being sold as an aftermarket at Way.
« Last Edit: June 15, 2011, 01:04:09 PM by MINI OOP » Logged
Herb
« Reply #4 on: June 15, 2011, 01:24:49 PM »
That shield Herb talks about I've heard is pretty good.  Also I haven't had a big warping issue since I opened up the scoop to let air thru.  It can be done by removing the black insert, or taking it out and dremelling the grid marks open.  I did it for a ram air kit I used to have (rusted out quick).  For mods, consider the CAI from Defenders of Speed, it is very effective.  I opted for the entire firewall piece pre-cut from them for ease of install.  Also consider the BSA Catch Can and Dual Boost Tap from Way Motor Works.  Helps keep the valve seats from building up crud.  Also if you cap off one of the taps and leave it accessible, you have a port to inject Sea-Foam into your intake easily.  Good for removing crud on valve seats.  The direct injected engines have an issue where the crud can build up and cause pre-mature engine failure.  See some of the other threads on here about others issues.
2FUN4ME
Kathy
« Reply #5 on: June 15, 2011, 03:29:43 PM »
Some warp and some do not.  I don't know why.  Weigh the odds, buy new scoop/buy new engine.  There are some scoop replacement options like carbon fiber and chrome you might like to view MossMINI.com
I am sure some other people will post about this topic.
« Reply #6 on: June 15, 2011, 06:34:17 PM »
Go with the Cold Air Intake (CAI) system. I have the K&N Typhoon works great and you don't have to cut anything. As for the heat shield wait, not a performance item ( change your oil more often than the dealer recommends. 5K to 8K) this will help the engine tremendous.  A Cat back exhaust system works to. (love the sound).
« Reply #7 on: June 15, 2011, 11:23:40 PM »
I'm gonna suggest a different direction. While an exhaust and cold air intake (CAI) will  help ya out a good deal. I'd suggest a good set of tires and a bigger/stiffer rear sway bay. Something like a 19 MM bar. I like my ALTA, but I'm also liking the new NM stuff, though it's pricey.
Our little cars make pretty good power, but suspension mods make you FEEL the car work more than go fast mods do. Just my opinion.
« Last Edit: June 16, 2011, 06:42:41 AM by 2FUN4ME » Logged
« Reply #8 on: June 16, 2011, 05:20:58 PM »
I see your point Dale, the sway bar did help the handling of the car.  I think now that I have the Defenders of Speed CAI, I could also get a front strut tower bar.  I guess what we're saying here is ya gotta make a personal decision on what ya want more, straight up go fast or better handling.  If you are like most of us, you will end up with both, but I guess it depends on which way you are inclined to lean first.
Have fun modding your MINI regardless where you start!  That's what make it yours!
circusmar
« Reply #9 on: June 19, 2011, 04:07:27 PM »
+1!
First mod: ditch the run flats and get something sticky in  205/50/r16. (get an emergency kit from slime or conti just in case).
Second mod: do the front camber mod (pull the locating screw/pin and push the front struts inward to their limit.
Third mod: 19mm swaybar. I personally like the H-Sport for the greaseable bushings (use Teflon tape on the bar also).
Assuming the 07 in question is an MCS due to heat shield question. I would only drop coin on a shield if my scoop were to melt. If it is an MCS an inter-cooler (I like the Forge) will make some real/measurable power. Next might be an ECU tune. I'd be careful about the Alta AccessPort, some love it, some hate it. I drove an MCSa with an AP tune and it was a peaky, laggy mess, the auto shift point tuning was terrible but I hear they have been working hard to sort it out. The gas mileage was noticeably worse.
In my opinion intakes and exhaust are more about sound than power but you will find those that swear by them. For a free sound upgrade take your boot lid out to hear your stock exhaust more. Also consider doing the noisemaker delete to get a more subtle, smoother intake note.
The stock brakes on an S are actually pretty good - have you changed out your fluid?
The JCW kit is worth a consideration, the badges by themselves add power!
Always be leery of "ModGoggles" and approach all recommendations with healthy skepticism. YMMV.
« Reply #10 on: June 19, 2011, 11:48:12 PM »
OK, my thoughts on mods.  If you want to go faster in twisties, do the swaybar.  Best suspension mod for the money.  Depending on how hard you want to take them, you can always opt to go bigger.  You have 19mm, 22mm, and 25mm options.
If you want to go faster overall, a tune is by far the best bang-for-the-buck.  Jan at RMW can get you as much as 35 HP and 35 lb/TQ for $600.  No other engine mod will get you that big of a gain.  Just check on NAM to see when he is having another tune session in either NC or DC.  It will well be worth the drive/effort.
« Reply #11 on: June 20, 2011, 06:17:38 PM »
As you can read we all have ideas for the first mod or any mod for that matter.  Just enjoy your car cause any mod will put a smile on your face. 055
« Reply #12 on: June 20, 2011, 09:11:50 PM »
Well put, Steve! 038
