speedfrk
« on: June 21, 2011, 05:29:58 PM » |
Are you all happy with the out put of your a/c system no matter the temperature outside? I bought my 07 MCS earlier in the Spring and when I checked the a/c system it appreared to be fine, but the first hot spell we had in May it didn't seem like it was putting out very cool air. I took it in to a local shop not knowing the whole time my warranty would have covered this and had them check the charge on the system. They told me it was a little high and when they got the charge back within spec that the coolest they could get the air coming out of the vents was 44 degrees and stated that they felt that the compressor was a little on the weak side. I looked at my warrandty and when I discovered that my entire a/c system was covered under warranty called Checkered Flag and scheduled an appointment for yesterday the 20th. They called me and left me a message late yesterday that my car was ready to be picked up. I picked it up this morning and was told by Frank Lindsay who was my service advisor that the technician who worked on my car that they couldn't find anything wrong with my a/c system and that they measured the air coming out of the vents at 28-30 degrees. So I take my car drive to work this morning and it was only in the low eighties by then and the system seemed to be working ok, but still not as cool as I'd like it to be. When I got out of work today to drive home the car measured the outside air temperature at 93 degrees and I had a 24 mile drive to get home. The air blowing out of the vents with the system on max and on recirc didn't seem all that cool(barely cool enough to keep me from sweating). When I got home I used to ifared thermometer and read the air temp coming out of the vents. I got a low of 48.5 at the innner drivers side vent and a high of 55-57 at the outer drivers side. I didn't even check the outer passenger side as at that point I figured what was the use as it was only going to be worse. I called Mr. Frank and if I understood him correctly he stated that the Mini a/c system blows out 45-50 cooler than the outside air temperature and that all though I was a little on the high side that it wasn't really that far off. I didn't argue with him, but just stated that my 2003 GMC Sierra P/U will run you out of the truck even at 100 degrees outside. He offered to check the system again and with my warranty give me a loaner car. It goes back in on July 5th. Is this the best this car is going to do? If so I'm very disappointed in this part of my purchase. There has got to be some issue with this thing. If this is it a Mini may end up not being for me. That would suck as other than that I really like this car, but being cool on a hot day is very important to me. I'd probably have to take it in the shorts to the tune of at least a couple a grand to dump it on a trade in, but I just may have to do just that.
« Reply #1 on: June 21, 2011, 08:28:35 PM » |
Coming back from the Blue Ridge Parkway Tour Sunday, we hit temps of 95 degrees. I hit the AC button and within 3 minutes, it was very comfortable in the Clubbie. I'd say have them check it out for ya. I had Tyler's 07 when we were down in Orlando a couple of weeks ago. It said 102 on the temp read out and within a few minutes, the AC had the interior of his car to a decent level. I'm thinking you just need a AC service of some sort.
Dale Blankenship Poquoson, VA 09 Laser Blue Clubman S Wife thinks it's hers! 07 Mellow Yellow Cooper S Of course son thinks it's his! Guess I need a third MINI!
speedfrk
« Reply #2 on: June 21, 2011, 09:13:11 PM » |
You don't understand it's been serviced by both an independent shop and Checkered Flag Mini. One says a weak compressor and the other says no issues at all. So once again what gives?
« Reply #3 on: June 21, 2011, 09:45:55 PM » |
At that point, I'd make a trek up to Crown MINI in Richmond. A third opinion can't hurt and several of our members, including myself, have had good experiences with their service department.
speedfrk
« Reply #4 on: June 22, 2011, 08:11:43 PM » |
It may come to that, but what if they say the same thing in that it's within spec. I like my a/c systems to blow cold enough to be able to run you out of the car after about five minutes no matter how hot it is outside.
« Reply #5 on: June 22, 2011, 11:12:45 PM » |
Make one of our upcoming meets. Check out someone elses MINI and have them check out yours. If we compare cars, you may see a difference. If so, then there may be an issue with yours. If not, well, not sure what to tell ya then.
« Reply #6 on: June 24, 2011, 11:15:57 AM » |
Question ? Do you have the Automatic Climate Control option ? If so, try turning off the "Automatic" part of the system. Just select a different set of vents when in Auto mode and it should run A/C only at full blast. Works well on my Gen 1 Mini.
 03 MCS Electric Blue/W. Alta CAI, Craven 15% S.C. Pulley, Screamin' Deamon Coil Pack, Magnecor comp. plug wires, Alta 2.5" V2 Catback exhaust, Alta air diverter and oil catch can.
MNI LIMO
« Reply #7 on: June 24, 2011, 04:41:43 PM » |
Make sure your a/c button is on. On mine it is the round button below the three vent opitions on the right side. If it's not on it will blow hot or warm air.
Don
speedfrk
« Reply #8 on: June 24, 2011, 08:39:50 PM » |
I appreciate the responces, but please give a me a little more credit for understanding the cars a/c system. It doesn't matter if you use the manual max setting, or have the automatic climate control on the lowest setting with the air set on recirc it yeilds the same result. It cools, but not very well. It never gets cool enough that you would ever want to turn either the temperature up, or the blower fan down. That is the part that is driving me crazy. I did get a call from management at checkered Flag today after filling out my online survey about my service appointment. The person on the phone stated that when I bring my car back on July 5th that the service manager would look into this along with the tech who will be assigned to it. Maybe I'll finally walk away happy. I'll give Checkered Flag credit in that at least they are going to try and make it right. I still think the compressor is either weak, or too small for the car to begin with. I've even thought about searching for an aftermarket unit that has a higher efficiency than the factory unit. Maybe an actual US company like Delco Remey might have a unit that would fit it, or at least find a manufacture somewhere else other than Asia.
« Reply #9 on: June 25, 2011, 12:01:31 AM » |
Pretty sure the compressor is more than up to the job. Both of mine are very well cooled and I've probably driven 15-20 more MINI's that have no cooling issues. Hopefully, they'll figure it out. could be (and probably is) something simple.
But still, between now and then, meet up with us and have one of the otherr MINI owners compare it to theirs just to be sure.
2FUN4ME
Kathy
moderators
Offline
It's not a car; it's a lifestyle
« Reply #10 on: June 25, 2011, 10:51:49 AM » |
I have an 09 and just started paying close attention to it so I could respond to this thread. If the sun is shining and it is very hot, the sunroof seems to keep it hotter inside and take longer to cool. On a cloudy hot day it seems much faster for cool down. As for the max usage. I turn the temp up and the fan down when my earlobes get chilly. Bottom line, I have no complaint. My 04 had a much harder time keeping the car cool. There was a noticible difference between the two cars.
 Apollo is my 09 MCSa MY/B #1, #3 Tuscan leather, oak trim & wheel. My hubbie and I met thru HR MINI!
speedfrk
« Reply #11 on: June 27, 2011, 01:29:50 PM » |
I rode in an 03 MCS over the weekend and after no more than five minutes the a/c was blowing out ice cubes. Now I'm really convinced there is something wrong with my system. I think I still smell a fight coming on as that's usually the way it goes for me. No matter how nice I try and be about it things go downhill fast and you end having to get nasty in order to get someone to make something happen. I'm still hoping Checkered Flag will come through, but if not I'm prepared to go to corporate levels and beyond if necessary.
Mini-less :(
Offline
Jeff
« Reply #12 on: June 27, 2011, 09:56:45 PM » |
I thought the same thing on my 07 since I bought it new in 07. It seemed a little weak, cooling-wise. I had my windows tinted, the sunroof is both tinted and covered in white vinyl and neither because of the AC, because I can't tolerate bright light. I will say that I rarely used the Max AC feature on mine or put it on recirculate until recently. It will positively run me out of the car on Max AC. With that being said, since I bought the car I've been put on prescriptions that have a side effect that make me tolerate heat much better but not tolerate cold worth a hoot.
What I do is run on regular AC with the temp set to the lowest setting and I run with the sunroofs popped to vent mode for a few minutes so that the car can chase the hot air out of itself while it's moving. Then I close the sunroofs and put it on Max AC and it cools off inside MUCH faster.
For what it's worth, I don't think Checkered Flag is giving you a line, I think that the AC system is a little on the weak side but it is tolerable IMHO. I also think that most American cars have over-sized AC systems and foreign manufacturers tend to be more conservative and considerate of size limitations and economy.
Jeff "Mercy is a contingency plan devised by the guilty in the eventuality that they are caught." - Kahlan Rahl
speedfrk
« Reply #13 on: June 28, 2011, 08:13:19 AM » |
I don't buy that all foreign car manufactures install conservative a/c systems. I believe it's a class problem with the the Gen 2 MCS based on your story and mine. I've owned two imports and have rode in several. They were all Asian manufactured, but the a/c systems in those cars worked just fine. They ran you out of the car in a matter of minutes due to being to cold. Once again we will just have to wait and see how this next appointment goes. Maybe the 2009 and up a/c compressor is stronger and they will put one of those on, or go the other direction and put a new Gen 1 compressor on my car as they seem to be a lot stronger.
speedfrk
« Reply #14 on: July 08, 2011, 07:55:19 PM » |
Well the second go around is no better than the first. I was given a 2011 MCS loaner car with only 1,000 miles on it while Checkered Flag had my car. In 95 degree heat by the time I got from the dealership to Greenbriar Pkwy the loaner car was blowing nice and cold and I had to turn the blower fan down. When I picked up my car and drove home from work yesterday my a/c really didn't work any better than when I took it in the first time(my car showed 94 degrees). The only difference was that by the time I had rode the the 24 miles from work to home the system seemed to finally be picking up steam and was cooling a little better. So now I've rode in a 2003 and a 2011 MCS and both cars a/c systems work the way I believe they are suppossed to. What Checkered Flag did differently this time was check the charge(found slightly low, but last time was ok when my car came in), evacuated the system, recharged it adding the dye additive to check for leaks, and was test driven 40 miles. I was told the tech reported that his hands were going numb on the test drive from being too cold(I call BS on this one). I'll wait for my next online survey, but I won't be nice this time. I'm going to start keeping a log book for the next couple weeks and then take my car to another Mini dealership(probably Richmond ) and go through this whole process again. They are going to learn I'm not going away. At this point they need to just admit they can't fix it and replace the whole dang system and be done with it. If it were me and I wanted to retain a customer and cared about my integrity I'd have already done just that.
