You are here: Home arrow Forum arrow Grease Pitsarrow Mods - Engine, chassis and otherwisearrow Oil drain bolt- BMW cross number?
Welcome, Guest. Please login or register. May 25, 2012, 04:35:36 AM
Author Topic: Oil drain bolt- BMW cross number?  (Read 388 times)
scott
« on: June 25, 2011, 11:07:54 AM »
I went to do my first oil change on my new to me R53 and the oil pan drain bolt is completely rounded off (this from a 100% dealer serviced car... 093)  The nearest Mini dealer to me is a 200 mile round trip (or I would just go and buy one), but there is a nearby BMW dealership.  Is there a BMW oil drain bolt that is the same as the R53's?
'06 Cooper S -Daily
'90 Miata STS autocrosser
'92 Spec Miata (SCCA/NASA)
www.weekendwarriorracing.com
www.driverelement.com
« Reply #1 on: June 25, 2011, 03:28:04 PM »
Not sure about the cross over from BMW to MINI on the oil pan plug, but you can get it (and any other oil change supplies) from MiniMania.  The plug is only about $6.
http://new.minimania.com/web/STSearch/MAINTENANCE_NM/SUBTYPE/SearchText/ShowIcons/Yes/ItemPropParents/MAINTENANCE_NM,MAINT_ENG_NM/CarSearch/NEW_MINI/Search_Inventory.cfm
Hope this helps!
« Reply #2 on: June 25, 2011, 05:31:39 PM »
Another option is the Fumoto Drain Plug:
http://www.fumotousa.com/nseries.htm
http://www.fumotousa.com/size_import.htm
There are two versions available:  with a nipple or without a nipple.
The nipple version allows you to attach a length of silicone tubing to the nipple so the oil flow can be directed into an oil recycling container.  You can quick-tie the tubing up & out of the way when not in use or reattach it when needed.
scott
« Reply #3 on: June 25, 2011, 10:58:00 PM »
Thanks for the replies, I ended up just going to Autozone and finding a replacement.  Turns out the size is M14x1.5 if anyone ever needs to know.  I eventually got the bolt out of the pan (that was a blast) Time for a frosty one after the longest oil change I have ever done and a special thanks to an unnamed Mini dealer.........
Moral of the story, don't always just the dealer to "do it right"
'06 Cooper S -Daily
« Reply #4 on: June 25, 2011, 11:24:09 PM »
Hope it doesn't rhyme with Fleckered Tag.
scott
« Reply #5 on: June 26, 2011, 11:31:40 AM »
 065
Rhymes with Frown in the state capital.......
'06 Cooper S -Daily
