Ok so I posted up on NAM looking for some insight as my Mini is having a small, but seriously annoying issue. Here is what I posted:
Ok, so long story short, when I bought my 06' MCS (54k miles), it came on stock SLites with Federal Tires, but the tires are worn out on the inside front and cupped in the rear with bad wear.
So I went to Discount Tire and bought brand new wheels (Drag DR38's in Charcoal) and Hankook Ventus V12 tires. I took the tires, got them mounted and had the front and rear tires balanced.
Before I put them on I installed my new Swift Lowering Springs and HSport rear lower Camber arms then went and got a four wheel alignment.
After that I went home and put the new wheels on. Discount Tire included plastic hub rings that fit correctly. I used the stock bolts, they fit in barely and I had to use a thin walled socket to put them on, but they seemed to go on ok. After I got them on and tightened them up, I took the car for a ride. Rode great until I get on the highway and then around 65mph the steering wheel starts to vibrate.
With the SLites on, while the tires had tons of road noise and NVH from being all tore up, they did not vibrate like the new wheels and tires are doing.
I have 2 thoughts in my head and I was wondering if anyone could provide other possible issues.
1.) The wheels need to be rebalanced as in the place didn't do it right.
2.) Do I need different wheel bolts for aftermarket wheels? The stock ones barely fit into the holes and may wobble? What do stock wheel bolts get torqued to?
Any insight you guys could provide would be great. I need to get off these ragged tires on the Slites, I'm sick of the noise.
Since then, I have gotten in contact with Discount Tire where I bought the wheels and had them send me a new set of hub rings and ordered Gorilla Spline drive lug nuts. The new hub rings were aluminum (sent for free, nice) and were the proper 73mm to 56.1mm, so I cleaned the center of the hub really well and lightly sanded off any surface rust. Reinstalled the wheels last night with the new hub rings and the new lug bolts and took it to work this morning. Still having a vibration at 60+ mph. When I say vibration, if I let go of the steering wheel it jars evenly back and forth slightly, the car still goes in a straight line, but I did not experience this issue with the slites on the car even with the chewed up tires.
So I'm thinking maybe they aren't balanced perfectly, but I am looking for a known good place to take it where others have had success to have the wheels looked at and rebalanced if necessary. I am in Norfolk, so the closer the better.
Thanks and sorry for the long read
