You are here: Home arrow Forum arrow Grease Pitsarrow Wheels and Tiresarrow What year wheels work withwhat year car
Welcome, Guest. Please login or register. May 25, 2012, 09:36:11 AM
Author Topic: What year wheels work withwhat year car  (Read 656 times)
Scottishblood
« on: January 29, 2007, 07:06:27 PM »
For exaple will wheels on a 05 work on my 06.  Scott told me one time but it went in one ear and out the other :smt102
Thanks
Jack
alvarospatchez
« Reply #1 on: January 29, 2007, 07:13:21 PM »
The bolt pattern hasnt changed for MINI all factory wheels should work with every year. Not sure if it's changing for '07 but up until now it's been 4X100
Scottishblood
« Reply #2 on: January 29, 2007, 07:19:29 PM »
I thought the diameter of the stud had changed at one time.
« Reply #3 on: January 29, 2007, 07:30:19 PM »
Yep..... bolt pattern has remained the same.  4x100
Lug bolt diameter and thread pitch has changed, since 7/06 I think.
BMW changed from a 12MM x 1.5 to a 14mm x 1.25.
http://www.txwerks.com/servlet/Detail?no=47
Texas Speedwerks is the only company with a conversion kit, that I know of.  If you read through thier site they explain in detail about about the science behind how the wheel stays put to the rotor.  It's not what you think.   :?
To answer your question Jack,  if your 06 was produced BEFORE July, they SHOULD fit!
Clear as mud I'd say.
~Sean
Scottishblood
« Reply #4 on: January 29, 2007, 07:36:15 PM »
I spied you tonight around 5:30 pm going down Baxter, you turnd right on to a side street.  Thanks for the info.
ScottRiqui
« Reply #5 on: January 29, 2007, 09:22:45 PM »
I think so far, all of the stock wheels fit either the 12mm or 14mm bolts.   I think the stock holes are 16mm in diameter.  I measured one of the 15" "holies", and they'll fit either size.
Riqui's car and mine both have the "Webspoke" wheels, and hers has the 12mm bolts, while mine has the 14mm bolts.
